Maxdsl
Maxdsl
I have a pci adsl modem when i connect to the internet it says I am connected at between 6 and 7.1 mb. Does that mean maxdsl is activated on my line. I requested within the forums and through the send maxdsl page but I have heard nothing If I do a speed test from plusnet I just get over 2mb but if I use the Bt one I get 6mb.
Two months ago occasionally get download speeds of around 4mb but nothing like that now
How can I tell if I am maxed now or not
Thanks Coley
alankay
Maxdsl
Sounds as though you are maxed...if you do the BT speedtest through the PlusNet portal [Help & support/Self test and raise a fault/BT broadband speedtest] the test results should make that clear i.e if the upstream figure is in the 400s you're maxed, also it will tell you what the actual throughput is...if this is a good deal lower than your IP profile raise a ticket. Hope this helps though I'm no expert! Smiley
Maxdsl
Thanks Alan for the reply its a chinese puzzlenet this place I guess there is no straight answer
ady
Maxdsl
literally any speed over 2mb is max Smiley
and if your upload rate is set at 448, then your deff max'd
