Maxdsl
grumpy_old_man
Maxdsl
Is maxdsl something that should happen automatically or do I have to apply to plusnet for them to upgrade line?
Currently I am achieving about 1.8mb.
Maxdsl
Hi Windaw,
What product are you currently using? also if you post your router stats here, we'll be able to tell you if you're already on the MaxDSL connection or not...
If you're not already on it, again, looking at your router stats will be able to tell us if it's worth changing over...
KR
Roger.
grumpy_old_man
Maxdsl
Voyager 205. You will have to forgive how do I find stats?
Maxdsl
Windaw
Look at www.kitz.com Under ADSL...
A
grumpy_old_man
Maxdsl
antandmand
Thanks, found them
Local Line attn 2.0
Local snp margin 36.0
Maxdsl
What's your current upstream and downstream data rates?
Plusnet Staff
Plusnet Staff
Fixes: 159
Maxdsl
You need to opt in for the MaxDSL upgrades, you can request this here.
 Chris Parr
 Plusnet Staff
grumpy_old_man
Maxdsl
Chris
Thank you for your reply. I have registered for an upgrade and await with anticipation.
grumpy_old_man
Maxdsl
Chris
Upgrade has taken place currently achieving 7616 Kbps on downstream and 448 Kbps on upstream.
