MaxDSL question.
MaxDSL question.
So, if MaxDSL allows the user to connect at the max the line will handle, what happens when 4+8meg are released UK wide?
Is it a case of our line syncing at a new speed and PN throttling us to 2meg? (unless we upgrade).
1 REPLY
Cloudmaster
MaxDSL question.
I believe your modem / router will continue to sync at 2Mb. PlusNET would have to get BT to upgrade you at your exchange if you wanted one of the higher speeds available. (AIUI)
