MaxDSL Equipment
essenby
MaxDSL Equipment
Does anyone have a reliable MaxDSL connection via a router?
My connection has been upgraded and I now regularly get just uner 3Mb connection via Speedtouch (not a brilliant line but it works!). So I bought a Linksys WAG54GS to take advantage of a faster LAN connection, but it refuses to connect (see other post). Reading through the myriad of other posts on people who have no connection at all - they all seem to be using routers rather than ADSL modems?
So does anyone have a MaxDSL connection AND a router - and if so, what part of the coutry are you in? (I'm in Sheffield)
BJ
MaxDSL Equipment
Fabulously stable using a D-Link DSL-G604T at work. (Between Leeds and Bradford - Laisterdyke exchange)
Lousy at home using Netgear DG834G (Pudsey Exchange - near Leeds)
Great at home using Binatone ADSL500 USB Modem.
Still need to re-work through the config on my router to get it back to spec, but should in theory be great too..
Alecto
MaxDSL Equipment
No probs with my connection and Netgear router.
Line stable and running at 4.5Mb.
I'd noticed what you say about modems, too, though perhaps more of the people on the forums use routers than use modems.
