Mail server problems
Anyone else run a mail server on their +net adsl? I can send mail out, but when I try and send it back it gets sent and never arrives. The router/firewall is setup correctly and forwards pop3/smtp/imap
I wouldn't mind if I get a delivery failure message but I get nothing. Any ideas?
Regards
Mark
I run exchange 2k3.
Works perfectly for me.
What server are you using? And how do you have it set up..? ie. mx records, simple forwarding and changing the SMTP record?
Am using ISmail, there's not really a lot to set up with it. I have set DNS to same as for ADSL connection and have checked the MX records and they are all ok.
Don't use forwarding as it sends mail out using own server and should receive it back using your userid.plus.com which resolves correctly as well. Just can;t work this out.
PM me an IM contact - I'll see if I can help you out :-).
Just logged onto my webmail and found the email messages I've been replying to. Not sure why they end up there instead of going to my server?
