Mac OS9.1+ router
Mac OS9.1+ router
I have connected a Solwise 110 router to my MacG4. Plusnet tellme theconnection is good, but I cannot get anything on my browser. Plusnet seem to have no clue about Macs, has anyone got any ideas?
RE: Mac OS9.1+ router
Is it just browsing that doesnt work, or is it everything?
The other question is how is your router connected to teh MAC? USB or Ethernet?
If Ethernet, Are you able to ping the router's IP number?
If you are not, assuming the Router has a DHCP server set up the MAC to collect IP numbers etc. automatically from DHCP and as long as the router is able to establish a connection to plusnet then Bob should be a close relative.
I don't use MACs at all but have set up such a connection with a peer to peer setup on 10 iMACS no problem.
Regards
Tim
p.s. If you are using USB. Sorry, no can help!
