MX records ?
MX records ?
The the tutorial giving the very instructions you need for this, in the Tutorials and FAQ forum.
MX records ?
Can someone give me a list of the domain records (and other portal email changed) I need to setup in order to use SMTP in conjunction with my exchange server/domain/static IP
thanks a lot for your help
cheers
Craig
painswck
MX records ?
Hi Craig,
Why not try Ben's answer in your other thread.
Dont add any extra records, change it to "I will use SMTP" and enter your IP address, that way we will still store your email if your server is unavailable and you can dequeue them using "finger postmaster@autoturn.plus.net
I did that and it competes the mx records for you.
Hope this helps.
[Moderator's note (by acarr): Removed duplicate reply]
MX records ?
beltin'
already setup now anyroad as Ive used the config that i have for my own SMTP exchange server config...
cheers anyroad matey
