MTU tweaks /setting on Vigor 2600
madswitcher
Hi all, I am playing with the above device and the line speed has dropped from 1.92 (Dlink dsl 504/MTU=147Cool to 1.97 with the draytek and same MTU setting.
Any ideas on what the best setting might be or where it can be set on the Draytek
Thanks, Mike
hi m8 i use the same modem/router as you i have my mtu 1458 and it seems to be ok. try that it might work.
madswitcher
Hi Grazz,
Yes I have tried MTU/RWIN settings of 1478/63272 (original), 1458/62392 and 1430/61160, all gave about the same speed of 1.86Mbps (used dr TCP)
I have just found the Telenet commands (yes it is a case of RTFM) and did
wan mtu 1478
to match the original Dr TCP setting, Set them up and got the speed back up to 1.92
Have you tried this -
Regards, Mike
