MTU settings (router)
May I also ask ... my router defaults with MTU at 1432. Should this be altered??
Thanks.
May be worth having a play with it but do make sure that you make a note of that number so you can put it back. Smiley
1342 seems to be a good average setting but you may get a tiny bit more speed by tweeking it.
What router? Some like lyncsys have an auto setting whic does it for you
also worth noting that some networks / sites are sensitive to MTU size -- Hotmail and MSN Messenger won't work if it's too large (>1470ish IIRC) for instance
Hi, I have the Belkin F5D9630UK4 - G+ MIMO 108MBPS MODEM ROUTER.
Thanks.
I tryed to change my belkin router f5d7632-4 from 1454 but it will not let me. It will only let me chance from 1400/1454 :?: Anyone solved this problem
