MTU settings on a PCI madem
has any one been able to modify the MTU setting on a pci modem!
as i am not to view my adapter!
RE: MTU settings on a PCI madem
Go to ADSL Guide they have a programme from B.T Openworld that will change the MTU of the PCI Card.
I did mine (plusnet pci modem) by clicking on the AccesssRunner Control panel icon, then hit "alt c" and it will give you 2 extra tabs.
Click on the Protocol Setup Tab and in the bottom left is 2 boxes showing maximum packet length, they both read 1500 change them both to 1458 then click apply and close.
It worked for me
