MTU Tweak Information - How to
If you want to 'Tweak' your DSL speeds try this website http://www.dslreports.com/tweaks
I was steered here by another Plusnet customer via my post in the Plusnet Community News Forum http://community.plus.net/ or http://community.plus.net/forum/index.php?topic=144.0
My last 'speed check' vis the Plusnet site came back at 5000kbps. Bit different ot the speeds I was getting earlier this week. I was very lucky to achieve 1500kbps
Cheesy
Plusnet Staff
Plusnet Staff
Fixes: 159
We have our own guide on MTU and RWIN here
 Chris Parr
 Plusnet Staff
holdtight
dennisb66
What connection speed do i use,up to 8mb or my actual speed attainable. :?
I presume you have gone through the tweak page on DSLreports.
I made the mistake of putting my attainable speed in and later was informed by a wiser man to put in your advertised speed i.e. 8000.
I am currently using the settings
RWIN 130200
MTU 1500
Follow this link for more info
dennisb66
Thanks Davlov will give it a try. Wink
dennisb66
System Up Time 104:18:21
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 5151787 5862967 0 20171 8636 34:17:42
LAN 10M/100M 6720 0 0 1 0 104:18:17
WLAN 11M/54M 6477215 5778289 0 4188 7385 104:18:08
ADSL Link Downstream Upstream
Connection Speed 2112 kbps 448 kbps
Line Attenuation 56 db 15.5 db
Noise Margin 15 db 19 db
Hi Davlo,after various tests,the above appear to be the lowest I can get.These are based on your settings.
Do you consider these figures acceptable,or too high.
I'm only passing on information that I had given to me by another Forum blogger.
I needed help to sort out my slow connection. I really have no idea about noise, attenuation etc. I am a only just starting to understand all this myself. You can get more help here
http://www.kitz.co.uk/adsl/tweak2.htm
dennisb66
No prob. Dave,thanks anyway. Wink
holdtight
Using your connection Speed of 2112 kbps what figures have you set your MTU & RWIN settings to using DRTCP ?
dennisb66
Hi there , RWIN 130456 MTU 1500
holdtight
Ok your rwin and mtu may be a bit high how is your speed with those settings ?
If your using a router you should have an option to change the MTU within the setup pages this is a good idea as then windows and the router see the same value, if not then just use DRTCP
Try these settings save then reboot and see if it makes any difference
dennisb66
Hi Holdtight, I have tried your settings and my speed didn't alter ie.1.4Mbps. BT have my line set at 1500Mbps.However my connection speed did drop slightly to 1984Kbps.
I have taken a look through my Router pages but couldn't find Option to change MTU.(possibly I couldn't see the wood for the trees).
I only applied wireless connection last week and BT upgraded my speed from 1000Mbps to 1500Mbps after 3 days. :lol: but still hopeing for more. Wink
Thanks Davlov
I've tried various settings before, but these worked a treat.
:idea:
If you go to this site, http://www.dslreports.com/tweaks and carry out the test, (you might have to be patient, the site has limited capacity and is very popular)
On the results page, enter DSL, 8000 (if your on 8mb), operating System (i.e. WinXP), and normal.
You will get a page of results, but at the bottom are the recommendations.
It is wise to download the tool, DRTCP and run it to make the changes.
I have change my RWIN to 151008 and MTU to 1500.
However, for some reason, my MTU reverts back to 1400 and I have no idea why.
Still, the improvement in the speeds and reliability are vastly improved. Depending on the site I am downloading from, I have seen speeds of 650kbps.
