MTU, TCP receive window default help
I change the setting to sort out my download speeds, but now BT as possible sorted out there hardware i want to see if the default settings work now.
I dont wanna do a full install again so i need the default settings, i use a USB modem and used Dr. TCP (Windows 2000/xp) to change the settings.
I need the default TCP receive window, Dail up (Ras)MTU settings please
Can anybody help me.
doesnt have the values i want at that link.
I have the tool to edit the setting just need the values.
If using Dr TCP, blanking all the values and saving will retore defaults.
