MTU DRtcp
MTU DRtcp
Does anyone use DRtcp and have the same problem as me?
Senario:
Platform: Windows XP
PlusNet Package: Home PCI Pack
When executing drtcp, you should get to choose an adapter, but unfortunatly for me, it's blank and I can't choose anything.
Does anyone have the solution to this?
RE: MTU DRtcp
I have the exactly the same problem. I found a guide on how to manually change the MTU in the registry:
http://www.adslguide.org.uk/guide/mtu.asp
I havent had a chance to try this yet as I am at work!
RE: MTU DRtcp
> Senario:
Q: What Operating systems are supported by DrTCP? (#3150)
A: The Following Windows OS's are supported by the newest version of DRTCP020.zip
I have had the same problem, check this site out!!
www.dslreports.com/tweaks/
Win95/Win95b/Win98/Win98SE/WinME/WinNT 4.0/Win2k/*WinXP
*Some WinXP users have have not been able to use DRTCP affectively.
RE: MTU DRtcp
> Senario:
Have you tried changing the Dial Up (RAS) MTU value in Dr. TCP?
Tim
RE: MTU DRtcp
> > Senario:
> Tim
I have tim it seems to improved the download speed, i set it to 1458
RE: MTU DRtcp
I have done that before, don't know if it had any effects though.
