MSN Connection
MSN Connection
Hi there
Further to my previous thread https://portal.plus.net/central/forums/viewtopic.php?t=14402
Still having problems - If dial up is used MSN messenger logs in without a hitch.
As soon as we have the DSL connection - It doesn't.
Someone said to me about open certain ports. I've got a list of the Ports - but could someone perhaps give me a hint to achieve this. It's a PN supplied Binatone modem with Windows 98/SE as the O/S?
Any suggestions would be great.
Obviously done the usual thing.. uninstalled/reinstalled MSN 6.1, stopped the firewall etc.
Thanks all
1 REPLY
MSN Connection
You only open ports on a router with a firewall.
USB modems have no such thing, hence the need for a software firewall.
No ports that will be used by MSN are blocked by plusnet.
Try registering again with MSN6.1 under a different user, the difference may be down to the IP address being static on DSL and dynamic on dial.
