MAXdsl enabled
MAXdsl enabled
Hi ive just checked on the exchange checker tool on both the plusnet site and also the usertools, and it says my exchange has been upgraded for 8MB use.
Im on 512Kb at the moment and was wondering what i need to do now in order to find out what MAX speed my line will take?
Thanks in advance,
Gordon
MAXdsl enabled
You have 2 options:
1) Wait until BT get around to actually enabling MaxDSL on your line (which may take several months) and you will know after 10 days.
2) Put your line stats into http://212.23.23.177/calc.htm
MAXdsl enabled
ok ive done the web checker thing and it says 2820Kbps is what i could get. So what do i do now on Plusnet in order to upgrade so I can get the maximum available to me?
MAXdsl enabled
You do nothing. PlusNet will be putting an order in to BTW to upgrade all their ADSL lines to MaxDSL on April 1st. It will take BT many months to do them all so it is impossible to say when your line will be enabled. You have to wait, just like the rest of us.
MAXdsl enabled
Ah i see, thanks for your help. Hopefully it will be a quick change and not a lengthy wait
MAXdsl enabled
hi there I have a speedtouch 330 adsl modem how do i find out these figures?SNR etc
thankyou
Peter
MAXdsl enabled
Click on the link below johnss99.
http://kitz.co.uk/adsl/frogstats.htm
MAXdsl enabled
thanks doing that now!
MAXdsl enabled
ok for some reason it says i have a proxy settings issue?? have gone through troubleshoot and its set up as they suggest and still no better? any ideas?
MAXdsl enabled
mine says 8000 odd on the calulator in that link and im already on the £40 8mb package when can i expect to see 8mb speeds?
