MAX and static IP
MAX and static IP
If I request an upgrade to MAX, will my static IP range change?
Plusnet Staff
Plusnet Staff
Fixes: 159
MAX and static IP
No, your static range will remain the same on MaxDSL or the fixed rate product.
 Chris Parr
 Plusnet Staff
MAX and static IP
Cheers.
Is there a price change if I request MAX?
Plusnet Staff
Plusnet Staff
Fixes: 159
MAX and static IP
The upgrade to Max is free and you can request it here
 Chris Parr
 Plusnet Staff
MAX and static IP
Thank you.
Final question: What outage can I expect to see when moving to MAX? I already know of the need to frequently drop the connection during the first 10 days.
Plusnet Leader
Plusnet Leader
MAX and static IP
When the upgrade is complete you need to reboot your router and you'll be away Cheesy
Plusnet Staff
Plusnet Staff
Fixes: 159
MAX and static IP
There shouldn't be any outage on a switch to Max, when you request the upgrade it will happen within 14 days. As you already seem aware of there may be some intermittent and speed fluctuations during the first 10 days.
 Chris Parr
 Plusnet Staff
MAX and static IP
Thank you very much for your help!
