Loss of sync suddenly
Hi
can someone look at ticket 22071742. Test result is inconclusive. To recap, I have had no issues until yesturday, when I could not get sync until 6PM in the evening. Today I can get no sync at all. I am on a fixed 1Meg service via IPStream, not LLU. Would appreciate any advice.
Mand
Have you tried with just the modem/router connected to the master socket? Are you able to try alternate hardware and/or filters?
Just ran a quick BT test and it indicates internal wiring/equipment as the cause.
If you have tried all of the above with no joy we'll get it raised to BT and get it sorted for you from there.
thanks mand, I will have a check of the internal wiring etc, and update the ticket
