Losing Sync with exchange when people ring
whenever people ring on the land line the my adsl modem (ive got the binatone one from plusnet) loses the connection.
Its starting to get annoying.
Any ideas on what the problem may be?
Ive got 3 phones connected to this line also if that helps.
Plusnet Staff
Plusnet Staff
It sounds like something on the line isn't filtered correctly.
Take a look at the following tutorial
http://portal.plus.net/central/forums/viewtopic.php?t=9996
regarding wiring and filters.
There have been 2 or 3 other threads where this problem was reported also. Try using the search to find them.
Do you get noise on your line when your modem/router is off and your phone is directly connected into the master socket?
If so, you may have a line fault and you will need to raise a fault call with BT.
Aaron
Moderators note (John) Duplicate post removed
