Looking for a new router
michaelscott
Hey all,
I'm looking for a new router that must be
* fairly cheap
* able to handle multiple external IPs
* able to understand that when I visit one of those IPs, I'm looking for the computer on the network and not the router
* be able to use one of those IPs for a group of desktop computers and give the others to servers
* fairly easy to use
Any suggestions?
craigbrass
Hello,
What type you looking for Wired or Wireless?
If you are wanting wired, go for the DG834 (http://www.netgear.com/products/details/DG834.php) costing about £30 on EBuyer and if you require addition machines to run, you can pick up a cheap ebuyer own brand 8 port hub for £15.
If you want to go wireless I recomend the DG834G from netgear (http://www.netgear.com/products/details/DG834G.php). You can pick it up for about £50 on Ebuyer.
Their URL is http://www.ebuyer.com
Yours,
Craig Brass
Hello
If you go down the wireless netgear DG834G route, check out
Amazon
As well as getting free delivery, you can also get a free Netgear Wireless USB 2.0 adapter worth £30. All in all both delivered for £69.99. Ebuyer and the like, I can only find them delivering the DG834G for around £70
mssystems
go for the DG834
Are you sure that will do everything the OP is asking for?
Our experience with persuading Netgear kit to do anything other than a basic domestic setup is not a good one!
Personally i would advise on a Draytek Vigor 2600+. Broadbandbuyer are about the cheapest supplier. You get a lot for your money (£100 ish) but the user interface is a little rough. Sonicwall kit can do pretty much the same stuff with an easier interface, but costs more.
* fairly cheap
Considering the feature set the 2600+ is very cheap.
You are talking about an IANA subnet. Yes it does that.
The trick is to have the routers external interface on it's own IP.
Thats a Dynamic IP Pool (DIP). You set aside a couple IP addresses which multiple outgoing connections can NAT through. Yes the 2600+ can do that.
Thats 1 to 1 IP mapping (MIP).
The 2600+ falls down a little here. It is 'fairly' easy to program - easier than a Cisco PIX for instance. The IP filters are tedious to set up though. Sonicwall's are a lot easier than Drayteks to program but cost about twice the price. For really flexible and easy to program, you need to start looking at policy based routers like Junipers and Fortigates, but they cost about 4 times the price of a Draytek
A word of warning. IMVHO the programming interface on a router does not provide a substitute for a network engineer that knows his onions. YMMV
Simon_M
Not cheap, but good value, with added bonus of being VoIP ready.
www.intertex.se
Helpful & knowledgeable user group with manufacturer input
http://ix66.techarena.org/forum
Post your requirement list on there & they will point you to the most suitable model.
Helpful dealer
http://www.etphones.net
& click any of the 'shop-on-line' links
or phone 0870 0683 299 & speak to Ed Keagan.
I use a wired router - the Speedtouch 510 V4. The shop I bought it from replaced the Netgear router I bought originally as my connection was continually cutting off. The Speedtouch is an excellent router in my view (and many other people's views as well as I have read lots of good reviews about it!). Cool
The router I have is this one with 4 ethernet ports. You can also buy the same model with a single ethernet socket. The four port router retails at approx £60.
Hope this helps. Smiley
The Netgear DG834 will suite the requirement you have, and is very easy to use and setup.
hiya
i had a netgear dg814 fine for ages then bt did something to
exchange for some reasons !
then constant disconnects
changed to linksys wag54g
hard wired and wifi router
lovely bit of kit never had probs
and also good for port forwarding to muliple pc's
which i had probs with dg814
but told the new netgear ones are good for it now?
well takecare everyone
Rob Cool
Try these people...
http://www.solwise.co.uk/
I found them very helpful when I got my router.
louiseandali wrote
Try these people...
I'll second that, bent over backwards for me, useful as I am an ignoramus. Shockedops:
