Login time ?
namtab
Login time ?
:? HI im new to BB, can anyone tell me is it normal to take 60secs to
log on to network, if not where am i going wrong ?
Login time ?
it takes me around 10 seconds at the very most.
not sure what the problem is though
Login time ?
Are you using an ADSL modem rather than a router?
If so in your dialup networking check to see if SPX/IP, NetBEUI and Log onto network are ticked. If they are then untick them. Only TCP/IP should be ticked.
Check the link:support pages for help in doing this depending on operating system.
Chris
namtab
login
:lol: Thanks m8, that sorted it.
