Login name
Login name
Is it possible to change my login name?
Login name
No, unfortunately it is not possible to change username, as it is so deeply embedded into the various systems that PN use.
Login name
But if you wish to change your username because you do not like it in your e-mail address. Then an alternative is to register a free dial-up pay as you go account, and use that for e-mail.
Providing you collect the e-mail regularly then you do not need to dial in, to keep the account active.
Chilly
