Logging On
Logging On
When I connect via adsl my PC takes anywhere between 25 to 40 seconds to log on and open Explorer.
Is the about average or do I have a problem.
Thanks in advance
fonejacker
RE: Logging On
Hi There,
I think you do have a problem! In your dial up networking settings do you have "Log onto Network" ticked. If you do then untick it and you should find that all becomes instant!
Regards,
Ian Wild
PlusNet Customer Support
RE: Logging On
That certainly worked for me - reduced my login time from a minute to about 5 seconds !
RE: Logging On
Wher is the "Log onto Network" which tab my be looking in the wrong place but it is not in the "WIP TECH" dialup for ADSL login. Also is it poss to reconfigure so that you do not have to click the "WIP TECH" icon to logon to the net.
RE: Logging On
Thanks for the info...made the alterations...will let you know if it works...
Cheers
