Linux drivers for usb dynamode a360 anyone have any ?
Hi ,
Just started using redhat 7.2 .
Does any one have any linux drivers ?
cheers Steve
This thread may help. Smiley
Steve
Did you get your Linux drivers?
Noticed your question on Linux Redhat support for the a360. I contacted Dynamode and they sent me a set of Linux drivers for 7.2 - can email them if you need them. I've just installed Linux 9 but the install doesn't work on 9 and Dynamode haven't yet finished doing the driver - do you have any ideas as to how I can make this work?
Jonathan
Dynamode
Hi ,
Dynamode emailed me drivers , however having problems installing onto Redhat 7.2
when run ./Install script , GUI fires up 1st screen has options upgrade or remove , select upgrade .
Receive message regarding installing rpm then pop box appears saying driver is not installed.
Can any one help me please.
Cheers Steve
[Moderator's note (by acarr): Removed duplicate reply]
