Linksys wag54gs - where do I find the line stats?
title says it all really.
Ray
This should help you
Line stats are only available on v2 of this router.
From the web interface http://192.168.1.1
> Status
> DSL Connection
Default username and password are "admin".
From Kitz
http://www.kitz.co.uk/adsl/frogstats.htm
Sadly that only gives line speeds :
Downstream Rate: 2272 Kbps
Upstream Rate: 288 Kbps
and not the signal to noise ratio etc.
Ray
It does......... just calls it something different "Margin"
Heres mine.
DSL Status : Up
DSL Modulation Mode : GDMT
DSL Path Mode : FAST
Downstream Rate : 2272 Kbps
Upstream Rate : 288 Kbps
Downstream Margin : 29 db
Upstream Margin : 31 db
Downstream Line Attenuation : 13
Upstream Line Attenuation : 8
Downstream Transmit Power : 0
Upstream Transmit Power : 0
L:shock: ks like I am missing something. Looky
Maybe the WAG54GS is not like the WAG54G version2
Ray
Sorry about: that I overlooked the fact that yours is a "54G" whereas mine is a "354G"
But a bit of a long shot try entering http://192.168.1.1/SysInfo.htm perhaps if it does not put the information on the main page it may show it there.No way I am sure though..... although I feel it must show the information somewhere.
A blank page comes up, entitled "(untitled)"
...and the status line says "done".
I've downloaded the sources for the firmware, I'll try and find some clues in that.
Maybe I should learn SNMP and see if that would let me in.
Little boxes, little boxes, little boxes made of tikky-takky
Ray
Unfortunately I have had it confirmed from Linksys support that Line Stats are not available on this model!
Dear XXXX, (amended)
Thank you for contacting Linksys Customer Support.
WAG54GS does not have the SNR (signal-to-noise ratio) or Line Attenuation compared to Netgear. In addition to that, there is no Linksys device/router which has the same capability.
If you have any further questions, feel free to visit our Knowledge Base at www.linksys.com/kb or send us an email at support@linksys.com so that we can assist you.
Sincerely,
Amended to delete name
Badge ID 15031
Product Support Specialist
Linksys – A Division Of Cisco System, Inc.
Website: www.linksys.com
Oh really? brackens, fence et al: the WAG54GS has SNMP functionality, and the SNR and attenuation figures can be seen using an SNMP browser such as MIB Browser. Using that I can tell you that my current downstream SNR margin is 30.2 dB, and attenuation is 34.0 dB. You certainly can't get at these figures from the web browser interface, but those stats are there alright, and many more. The "hidden pages" that have been mentioned related to WAG354G models don't work for GS or GX2 models, I believe.
Hi @bracken,
Thanks for that!
I have found here on the forum Tutorials & FAQ : Obtaining line stats from a Linksys Router
Linky
It describes using SNMP to pull the data out.
Ray
So that's where pcsni put it...:mrgreen:
@fence
Were you sucessfull? when I tried it a while back, I couldn't find an ADSL-LINE-MIB file listed for either localhost 127.0.0.1 or the IP Address of the router?
brackens, you've got to download that ADSL-LINE-MIB file from the relevant website, then unzip it and load it into MIB Browser. But you did that of course! Then you configure MIB Browser with your router's IP address and SNMP details etc., make sure SNMP is enabled on the router, and walk the MIB.
ske 1fr
Oops, your instructions couldn't have been clearer but I still forgot that bit Shockedops:
All working now though. Many thanks Cheesy
(smacks forehead with palm of hand):roll:
Please tell me you're not getting the same figures as me in the example. Mine is rock steady at that rate.
