Linksys WAG54G
Linksys WAG54G
Does anyone know if the CD and the software which come in the package with the ASDL modem/router can be read and used on Mac?
Thanks.
Linksys WAG54G
I never used the CD on my PC. Note: it is best to configure the router via an Ethernet connection first and make sure you upgarde the firmware to 1.05.00.
The router can be configured completely via it's web interface so you don't need to install any special software on the Mac or PC. As long as the Mac is configued to obtain it's IP address via DHCP or automatically, all you need to do is plug the router into the Mac and point your browser at 192.168.0.1.
holdtight
Linksys WAG54G
Peter, where did you see the firmware upgrade for this
router as according to the linksys site there are no firmware
updates available from them
i have also done a search for firmware for the wag54g
with no luck
as my firmware is version 1.01.6 and you say there is 1.05.00
im very keen to get the updated one
cheers in advance
Linksys WAG54G
Oops! Shockedops: Sorry, I was talking about the netgear DG834 (just answered an thread on that router and got stuck in netgear mode).
As far as I know the linksys can be configured from a browser just like the netgear so you should not need to install any software. The default address is 192.168.1.1 for that router and not he one I gave earlier which is for the netgear.
holdtight
Linksys WAG54G
your forgiven Peter Wink its easy done with so many topics going on!
had my hopes up for an update though,
maybe linksys will oblige one day Cheesy
yes the default Browser for the linksys is as you say 192.168.1.1
and a very easy one to set up and configure too,
the disk that is supplied with it is just a user guide and manual
which i would suggest reading if this is the first wireless router
youve had chiuuk
no software or drivers are on the disk as there not needed
one of the best routers ive had
Linksys WAG54G
Thanks very much for all the advice.
I now feel confident enough to take the thing out of the box and have a go.
Hope I will get it up and running without much pain.
Cheers.
chiuuk
Linksys WAG54G
latest firmware can be found [url=http://www.linksys.com/international/firmware.asp?intfwid=32&coid=6]here[/url/
currently at version 1.02.1
Annex A is the one I used.
holdtight
Linksys WAG54G
Thanks Chris
updated without a hitch all running smoothly Cheesy Cheers !!!
if you follow the links for the wag54g on the linksys site
it comes up no firmware available
dont know how you found it but thanks a lot
