Line stats & SNR - How?
octafish
Below are the figures for my modem (D-Link 300T). I don't see SNR anywhere, unless I'm being very dim.
Can anyone please advise as to how I get my SNR from theses figures? How near to 8Mb am I likely to get?......
Ta.
Steve
Modem Status
Connection Status Connected
Upstream Rate (Kbps) 288
Downstream Rate (Kbps) 2272
US Margin 28
DS Margin 31
Modulation GDMT
LOS Errors 0
DS Line Attenuation 15
US Line Attenuation 16
Path Mode Fast Path
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
Unless I'm mistaken then your SNR is your DS Margin, going by those figures you should get a speed of 8mb or close to it
octafish
Thanks. I see, that seems to make sense.
I've checked on http://212.23.23.177/calc.asp and indeed that gives me a theoretical 8192kbps.
Wait and see I suppose.
If I want to recheck the modem stats do I need to switch it off and on again or will it update dynamically?
Steve
it should update dynamically, however having never used that router i can't really comment, but all the routers i have used in the past do indded update dynamically
octafish
Thanks again.
I put in a new ADSL filter (XF-1e) and it left the downspeed SNR at 31 but boosted the upspeed one from 28 to 30.
Is 31 'good-ish' for SNR or should I try and get better somehow.
Steve
31 is VERY good. No need to try and get it any higher.
octafish
Thanks Peter. I'm now looking forward to the increase with a little less anxiety..... but the proof of the pudding etc etc
Steve
jagger
Downstream line attenuation looks good too.A figure of 15 is yards from the exchange,not miles.
Must be the best phone line in the country.Lucky thing you. Cheesy
chymorva
Maybe not Wink
Mine are:
Downstream: SNR 35, Attn 9.9
Upstream: SNR 30, Attn 6.5
Cheesy Cheesy
octafish
Would be nice to think so.
I'm about 1/3 mile from the exchange but my modem/router sits at the end of no less than 3 separate extension cables...... I have to say that my speeds are always between 1840 and 1940 kbps (2MB line).
Steve
Definately get a wireless router and put it right next to the main phone socket. Smiley
Where did you get your ADSL filters from and which brand? I'm looking to improve my SNR from 22ish
octafish
carlgm
Go to http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=1652
for the adsl nation XF-1e.
Steve
