Line not sync. some nights.
My broadband connection has been working fine for the last six months or so but over the last 10 nights or so half the time I cannot get a sync. line.
I have a dynamode PCI modem, when it will not sync. it mostly says "line down" but sometimes gets as far as "training".
When it I do get a sync. line everything is working perfectly. I contact BT, they say my line is OK.
Anybody any idea what the problem might be? I thought to start with my modem had "blown up" but as it works some nights the hardware muxt be OK.
Tom
Have you connected any new phones recently.
Are all your phones connected via ADSL filter/splitters (including sky boxes, faxes, 56k modems)?
Does the same thing happen if you disconnect all phones and only have the ADSL modem connected?
Does the same thing happen if you connect directly to the BT master socket?
I had tried everything apart from connecting to the master socket (its in another room).
Anyway everything seems to be working Ok again now. I fancy my problem might have been related to the ADSL upgrade work BT have been doing or a problem at my local ADSL exchange.
Tom
