Laptop-connection
silvercliff
Laptop-connection
Hi All
I now have a Laptop PC as well as my other one at home.
Can some one give me info on the best way to include the Laptop along with my Home one using my excisting Broadband connection :idea:
Obliged Job
Laptop-connection
Assuming you are using a USB modem at present, then you need to replace this with a router. Probably the most recommended router on these forums is the Netgear DG834G which is very easy to use, has a built in modem and allows you to connect via a wire or wirelessly:
http://www.netgear.co.uk/wireless_adslrouter_dg834g.php
Does your laptop have a built in wireless card? If not, and you want to connect your laptop wirelessly, then you will need to buy a wireless adapter for it.
silvercliff
Laptop-connection
Hi ruslyn77
Yes it has a Wireless LAN / also Ethernet/ LAN Port
Thankyou very much for your help.
Obliged Job
