Laggy Xbox Live and high pings
Morning,
Is anyone else experiencing very high pings to the xbox live service and general web access this morning?
Pinging www.bbc.net.uk [212.58.224.113] with 32 bytes of data:
Reply from 212.58.224.113: bytes=32 time=134ms TTL=250
Reply from 212.58.224.113: bytes=32 time=132ms TTL=250
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=144ms TTL=248
Reply from 212.159.8.137: bytes=32 time=142ms TTL=248
Reply from 212.159.8.137: bytes=32 time=149ms TTL=248
Reply from 212.159.8.137: bytes=32 time=145ms TTL=248
This has been happening quite often over the last week.
1 REPLY
legoyoda
I remember reading on here that if you are one of the customers with "up to 8Mb" you'll need to check the "connection settings" part of the plus net member centre.
Check for "Broardband Interleaving" if it's on they have increased the latency of your connection for higher stable max speed. If you're a gamer this isn't actually a good thing. You should have the option of turning it off but this means you might have to boot your modem / router and settle for a lower max speed.
Also, there are 3 ports you need to open up if you are using a router. Can't remember them off hand but if you google it I'm sure they will come up. Opening these ports has solved ALL my connection issues with Live!
hope that helps.
