Lack of Knowledge = DSL [removed] up !!
Hi!
I've just changed to Plusnet at work from BT-I had the whole thing working great using the Intel BT modem-then I decided to network ! 2x wifi cards,Netgear Access Point etc.-no more internet !! I can't even get back to square one -ie-no network just access from one PC-
any advice would be appreciated.
Bill :roll:
[Moderator note by phil (acarr) : Removed foul language from subject. This breaks the link]
what did you chage?
do youhave the right numbers to dial?
do you have the right wires in teh right places?
is the modem / router on?
is it plugged in?
is your home LAN set up correctly?
see www.buzzons.co.uk/tutorials/network.jpg
more info pleaseHuh
buz
dsl muck-up
Hi!
Thanks- The modem seems OK although I am using my old BT Intel 3240 for Plusnet -the main problem seems to involve
PP oA (can't see this)
PPoE Wan Miniport
-all a bit hazy to me .
Bill
update on dsl bodge
Hi! again
I'm getting nearer-I dug out my Broadband Blaster DSL Router(which I've been too nervous to use !!) and I've managed to connect to creative.com config page but I'm not there yet-I have hopes tomorrow!
I still have the wireless network to grapple with but that can wait awhile till the headache subsides!!
Will I ever really understand !!??
Thank s for the advice Shockedops:
Bill
