LOOK!!!! ADSL nightmare revisited
Grimbo
You mark my words.... the ADSL fiasco is starting again.
I noticed it early last time - I still have the emails where Plusnet were denying anything was amiss and trying to blame my hardware, my drivers, my friends ISP, allsorts!!!
This is exactly how it started last time.
I can connect with my 56K modem and get better pings than via ADSL.
RE: LOOK!!!! ADSL nightmare revisited
More tests tonight reveal the following:
Ping times to various game servers are over 350ms nearly all with packet loss i.e. totally unplayable.
Downloading a file with 10 connections using DAP and still only get 25KB/s MAX out of possible 60KB/s i.e. bandwidth problems again?!
Tweak Tests @ dslreports.com are failing in most areas e.g. "no ping reported", "transfer rate = 56kbit/s"
I only just tweaked my connection (change RWIN to 32120) and noticed the immediate download improvement a week ago but this is definitely not my fault this time.
Maybe they are doing something we don't know about...
new results:
C:\>ping -n 10 www.plus.net
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=71ms TTL=249
Reply from 212.159.8.137: bytes=32 time=59ms TTL=249
Reply from 212.159.8.137: bytes=32 time=37ms TTL=249
Reply from 212.159.8.137: bytes=32 time=58ms TTL=249
Reply from 212.159.8.137: bytes=32 time=62ms TTL=249
Reply from 212.159.8.137: bytes=32 time=24ms TTL=249
Reply from 212.159.8.137: bytes=32 time=27ms TTL=249
Reply from 212.159.8.137: bytes=32 time=25ms TTL=249
Ping statistics for 212.159.8.137:
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 24ms, Maximum = 71ms, Average = 41ms
This bollox my 56k modem goes faster than what i am gettin now, packet loss is through the roof, pings are ***** to say the least i think i will be going cable maybe next year i am not happy at all cos i cant see BT doin anything wot so ever about fixing the probs...
Grimbo
The problems are not with BT, the problems are with Plusnet and their connection to BT.
Have run a series of bandwidth tests this morning and speed is like a yoyo on "speed" one minute, "downers" the next. Not the best annalogy in the world I know but am sure you know what I mean. So problem is certainly not confined to the so called "busy" periods.
So, heres hoping that "fix" to all these problems experienced by so many loyal customers of yours plusnet is completed very soon.
Why oh why did I sign up for a yearHuhHuh?
Yes I have read the status connectivity notices by customer support. They may be doing their best(perhaps not), how are we to know?
