LLU broadband service
How would I find out if I am getting this? When I check my number over at http://www.samknows.com/broadband/phoneno.php and click on my exchange, I see that LLU services are available at my exchange but is PlusNet one of the ISPs providing this?
http://usertools.plus.net/@gateway will tell you if you are on LLU or not.
This says:
'You are currently connected to the "Telehouse East,
Juniper 4" gateway. This gateway is sometimes known as pte-ag2.'
I have no idea what this means. Am I getting a LLU broadband service then?
Zathras
No youre not on LLU
You are currently connected to the "Telehouse North, E320 ERX" gateway. This gateway is sometimes known as thn-ag2.
If you are on this gateway, you are on the Tiscali LLU Platform.
There are several gateways (equipment that your connection goes through) which connects you from BT/Tisclai to PlusNet. Only one, thn-ag2, is used for LLU connections. If it does not mention LLU, you are not on it and you are unlikely to be move to it either as PN stopped moving people over last year.
