LLU Platform
aviationradio
LLU Platform
Hello can anybody please tell me if my account has been transfered to the Tiscali LLU Platform.
I received an e mail from Plus.Net saying that i would be moved to the LLU platform on the 31 July 2006 - since receiving that mail i have not heard anything at all.
Is my connection or what ever now on the LLU platform or not - i would just like to know one way or the other.
Many Thanks.
T Tankard.
LLU Platform
Try browsing to ...
http://usertools.plus.net/@gateway
I understand that all LLU connections use the 'ptn-ag1' gateway.
Alternatively try and perform a BT speed test as detailed here ...
http://usertools.plus.net/tutorials/id/27
If you have been migrated to LLU, then it will not be possible use the BT speed tester.
Hope that helps.
aviationradio
Gateway
Hello.
Thanks for the reply,i have just been to the below url.
http://usertools.plus.net@gateway
It shows me as currently connected to Telehouse north,juniper2" - this gateway is sometimes known as ptn-ag2
I was also allowed to do the BT Speed test so i guess i am not on the LLU Platform but still on BT.
Am i correct.
Cheers.
Terry.
LLU Platform
Looks like you're still on BT
Dial 0800443311 from your ADSL-enabled landline, choose option 1 and then 3. This will tell you if you've had any orders placed against your landline.
aviationradio
Order
Thanks for the further info - just rung the BT # selected option 1 and then option 3 - was told no records of any orders - guess PN has not placed the order - so much for the transfer being done on the 31 July.
Thanks for the help.
Terry.
LLU Platform
I seem to be on 'ptn-ag1', and I failed to even get my router to connect using 'speedtest@speedtest_domain' does that mean I'm on LLU, or should I be able to connect and fail only to execute the speed test itself?
shellsong
LLU Platform
Sounds like LLU to me!
aviationradio
Opt out
Hi.
As it seems that lots of users are having problems with LLU - i wonder would it be possible to opt out of the LLU transfer after i have opted in for it - it does not seem that an order has been put in by PN yet.
Any ideas i wonder.
Terry.
shellsong
LLU Platform
It's worth a try-- there are some advantages to LLU if it works for you, one example being the higher upload speeds but you'll never get me up in one of them things without a parachute! Tongue If they sort out a proper MAC arrangement I might reconsider Wink
