Keep getting disconnected this morning
Anyone find their connection keeps dropping dropping this morning?
I've had to reconnect 3 times in the space of 20 minutes - each time waiting for my modem to initialise the connection again.
painswck
Sorry of no help but I have just checked my router log and no disconnections this morning.
Hope you get it sorted soon.
Roland
check your router/modem attenuation figures once synched, if there higher than normal then probably a local exchange problem. If so lift your phones handset and dial one Single number, do you hear a hiss/white noise? If so phone BT and report a line fault.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
easyc - yr connection working yet? Mine's been dropping all day...
thanks - its ok now
Weird, :?
After I posted there were no more problems.
Thanks for the advice though chaps, I knew a few of you would be able to help!
Cheers
