Kazaa
Kazaa
Over the weekend I have been using Kazaa and it seems to "hang" after probably half an hour. This also then affects e-mail and internet access. I then have to reboot pc and reconnect but same problem occurs.
Is this happening to anyone else or is this just an after effect of the DNS problems I've been reading about in the forum?
Cheers
Martin
chino
RE: Kazaa
What type of account do you have eg adsl home or home surf as the adsl home surf has blocked kazza and other P2P appz.
cUnDaLl
RE: Kazaa
> cUnDaLl
It's the ADSL Home. I've had it best part of two months now and had no problem with it before.
chino
RE: Kazaa
Do you have a firewall if so please try turing it off also download the latest version of kazza lite (no spy ware and pop ups) search for it on google.
cUnDaLl
RE: Kazaa
Or..
Go to http://www.k-lite.tk
Also note, if you have used Kazaa, remember to download the tools to remove the spyware that will already be on your system.
Enjoy.
chino
RE: Kazaa
Yes Mr Tack i should of provided a link, however i was just plain lazy.
P.S. There are many other P2P appz such as Soul Seek (very very good), Direct Connect (invite only in to the good hubs and up to 20gig min share) ect ect
cUnDaLl
RE: Kazaa
K, Note my name is Mr Tac, not Mr Tack
chino
RE: Kazaa
Sorry i did it from memory eg you details were not passed accross (god i must be getting old)
cUnDaLl
RE: Kazaa
Lazy... Forgetting things...
Yup Tongue
