Just Started
Just Started
Just signed up for plus-net, and assuming I can get connected, I'll need some kit inc modem etc. Any recommendations as to what this ought to be. Basic requirements are:
- a modem to plug in the router
- the router must be wireless
- 3 x PC cards must be PCI: NO USB
1 REPLY
RE: Just Started
Not quite sure what you are after her i.e why a seperate modem and router?
If starting from scratch I would go for a D-link DSL504 which is a compned router and modem with 4 ports for connecting a network.
Network cards can be got quite cheaply at about £10 to £20 each depending on the brand.
The DSL504 will cope with 10 or 100 meg network.
Hope this helps
