Joining PlusNet on 02/12/2005 - How do my line stats look?
Here are my line stats on my D-Link G604T router
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 288
Downstream Rate (Kbps) 1152
US Margin 31
DS Margin 31
Modulation MMODE
LOS Errors 0
DS Line Attenuation 18
US Line Attenuation 15
Path Mode Fast Path
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
How do they look?
I am connecting to a 2MB service with PlusNet at the end of the week Smiley
When 8MB or higher is available are those results good enough to upgrade to the higher speeds?
Thanks all
P.S. I am currently on a 1MB connection with another BB supplier.(TalkTalk)
csogilvie
I think you should be able to get 2MB (And probably higher) with those stats.
Thanks Colin,
I have signed up for 2Meg anyway so hopefully I wont get any problems and when speeds increase I will be able to take advantage of that aswell then Smiley Smiley
