Its that noisy line again.
Fantasticfourum
Let me start by saying when i disconnect my broadband and just plug my phone in the line is quiet so i have established this is not a line fault, now when i plug my modem into the filter i get crackly orrible noises so bad sometimes you cant here the other person it also disconnects me....I have changed the filter twice and bought a new phone and this still happens... Should i change my modem has anyone any ideas what is causing the noise as it can be really annoying, this only does it at random times with no pattern to the times it does it, just to make it even more annoying.....
Plusnet Staff
Plusnet Staff
Could be a few different things that's causing it, you've eliminated most of the common causes but there could be other reasons.
I'd suggest first to take a look at this:
http://usertools.plus.net/tutorials/id/13
to see if anything helps. I'd also suggest swapping the modem lead if you can as that could easily be the cause.
Fantasticfourum
Many Thanks for your reply
