It's easier calling the Pope than Plusnet!
Call plusnet regarding any issue and after navigating through 3 or 4 levels you will more than likely be told to do the task online, then the phone line is cut!
Now that is Customer Service!!!!!
craiglay
Its easier calling the pope than PlusNET
Have you tried!! :lol:
Seriously.. If you have access to an internet connection, it is probably easier to raise a ticket via the online help, and probably cheaper...
Craig
Well I have not had any phone calls from "bourgdubost".
Chilly
I got the queens residence last week Shockedops:
shellsong
I suppose it might be better than nothing but I suspect he might not be able to help with your broadband enquiries unless he could put you in touch with a priest, monk or cardinal who is knowledgeable in such matters! Wink (A Vatican Bright Spark?!)
