Is this what I need?
Hello All,
I have signed up this week and so will be joining the world of broadband ADSL.
I have gone for the self install and so have to purchase my own router. Could anyone offer me some support in what they would say is a good router. I have always enjoyed the performance I have had from my USR and so I would like to go with a name I can trust. I am not sure though if the USR18000 is what I am supposed to be looking at.
http://www.action.com/uk/apps/productpresentation/index.php?product_id=USRNA0294T
From what I understand is I need an ADSL router and so is this going to do the job or do I need some sort of modem built in?
Any help would be much appreciated, thanks.
Bruce
1 REPLY
RE: Is this what I need?
You will need to purchase either a router with an inbuilt modem or a router that will accept connection from an ADSL modem (such as the Vigor 2200USB from Draytek). Some routers with in built modems are : -
Alcatel Speedtouch 510
Netgear DG814
Vigor 2600 (available end May)
Unless you specifically want a router (to share your connection) an ADSL modem would do the job and would be much easier to set-up.
Hope this helps.
> Hello All,
> Bruce
