Is this the best speed?
amcbride
Received e mail saying I was to be "maxed" on 6th October. Have had the usual disconnections and checked my speeds and found a slight increase but not astonishing. Before I was maxed told the max speed on my line was 1Mbps and this is what my speed touch (frog) modem is still showing.
However when I check with PN is says Your current broadband speed is 2000 Kbps.
BT speed tests are showing between 830 and 963 kilo bits per second (Kbps).
My question is this the best I can expect? Or should I be getting something better? If so should I raise a ticket or is it a waste of time?
shellsong
What are your line statistics-- Synch Rates, Attenuations and SNRs?
amcbride
Is there a program that can tell you your line stats? Can`t see them displayed on my frog (speed touch usb).
shellsong
Look at the top of the page on http://www.kitz.co.uk/adsl/frogstats.htm
