Is there a way to limit my upload speed?
I was wondering if it is possible to tell your computer to only upload at 10kbps? or even lower?
If so, can you please tell me how?
Yes, however, this will heavily depend on what software you are using.
Windows has no method of limiting bandwidth.
Some software like P2P applications, has the ability to limit the upload speeds.
Another option it to purchase expensive hardware equipment to do it Tongue
in XP or win2k you can use QOS to set the bandwidth and if you havent change it XP will hog over 20% of you bandwidth for its self.
There is a lot to it so you will have to read up on it check MS sites for QOS
