Is there a speed problem tonight?
I'm down to:
"Your current bandwidth reading is:
173.20kbps
which means you can download at 21.65 KB/sec. from our servers."
Nothing showing under Service Status"
RE: Is there a speed problem tonight?
I don't think so.
PlusNet speed report here is: 346.7 kbps
From ADSLGuide: 460 kbps
Geoff
> I don't think so.
> Geoff
452.8 kbps at the min here,connected at 576
I'm getting problems.
Ping from google:
Reply from 216.239.51.100: bytes=32 time=94ms TTL=48
Reply from 216.239.51.100: bytes=32 time=235ms TTL=48
Request timed out.
Reply from 216.239.51.100: bytes=32 time=172ms TTL=48
Reply from 216.239.51.100: bytes=32 time=250ms TTL=48
Reply from 216.239.51.100: bytes=32 time=219ms TTL=48
Reply from 216.239.51.100: bytes=32 time=266ms TTL=48
Request timed out.
Reply from 216.239.51.100: bytes=32 time=297ms TTL=48
Request timed out.
Reply from 216.239.51.100: bytes=32 time=203ms TTL=48
Reply from 216.239.51.100: bytes=32 time=109ms TTL=48
Reply from 216.239.51.100: bytes=32 time=234ms TTL=48
Reply from 216.239.51.100: bytes=32 time=188ms TTL=48
Reply from 216.239.51.100: bytes=32 time=281ms TTL=48
Request timed out.
Request timed out.
Reply from 216.239.51.100: bytes=32 time=156ms TTL=48
Request timed out.
Reply from 216.239.51.100: bytes=32 time=78ms TTL=48
Reply from 216.239.51.100: bytes=32 time=93ms TTL=48
The ping is all over the place. Other sites don't get the timeouts but ping still all over
