Is my ADSL ok for 2Mb
Robtheplod
Hi All
I'm in the process of getting 2Mb ADSL but wondered if my line is ok ?
Settings as read from my router are:
SNR Margin 33.5
Loop Att 34.0
is this ok ??
rob
1 REPLY
Yep, you should have no problem getting 2MB. The limit for Attenuation on 2MB is 43db so you're within that, and your SNR (signal to noise ratio) is quite high, which is also good.
Also, if your upgrade fails (touch wood!), then you would be fully refunded for it - so there's no risk.
