Is it true that.........
on the adsl £20.99 a month package you cant use p2p applications like kazaa?
if so will it be possibly be changed in the future or is an upgrade required?
this is annoyoing as i didnt see were it said this when signing up, obviosly it was hidden in small print somewhere i didnt look
1 REPLY
RE: Is it true that.........
Says it right on the product description page man
http://portal.plus.net/info2/residential/res_broadband_adslhomesurf_selfinstall.html
You have to upgrade to the higher priced home account if you want p2p/usenet binary access (the reason why its only 20.99 is because of the bandwidth costs saved in not allowing p2p/usenet)
