Is it possible to use VPN with the AR11 router
bluewhale
Is it possible to use VPN with the AR11 router?
RE: Is it possible to use VPN with the AR11 router
From the manual at http://www.aceex.com.tw/catalog.asp?pid=a-004
"Does the ADSL Router support IPsec?
No, not currently. "
So that means it probably won't work with most VPN implementations.
Regards,
Ian Wild
PlusNet Customer Support
bluewhale
Thanks, oh well... Cry
