Is anyone else having FTP problems?
I can connect to my Plus net FTP, but when I try and run any commands on the server they just time out.
Help?
Which server are you trying to connect to?
The main one with your files in htdocs or the CGI Server called criticalmass?
The Htdocs one. Everything seems to be sorted out now though, thanks for the response!
No problem. Glad to help if I can. Smiley
