Is Router Upgrade Reqruied?
Hey
Currently I am using a Belkin ADSL Modem with Wireless-G Router. Would I need to to upgrade to to use the 8mbps when i get upgradeed or does that upgrade only needed if you used ADSL+.
You will not need a router upgrade unless you get ADSL 2+
Thanks alot.
You'll need plenty pf patience though :roll:
Hahaha now thats what i am short of.
Oh another quick question, what would my upload be?
