Is PlusNet blocking ports?
Is PlusNet blocking incoming ports 6700-6702?
nope more likely your router/modem or firewall, also a combo of the 2 are if you are not on the £18.99 per month package which does block p2p
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
I am on a 1Mb Home ADSL connection, paying £32.99 per month...
Plusnet Staff
Plusnet Staff
The only port we have blocked on the network is 135 due to the Blaster and varient virii. There are no other ports blocked on ADSL Home.
musica:
have u try see if your router set the port open?
that could be the case..
:roll:
I believe that the Port Forwarding is set to open...
Start Port: 6700
End Port: 6700
Server IP Address: 192.168.0.2
Start Port: 6701
End Port: 6701
Start Port: 6702
End Port: 6702
hi again:
sorry forgot to put this down on previous post
i know this is unusal:
just see that if you set the if that the case?
as my router have these setting :roll:
- Use the following form to add special port range that you want to be opened for your special application, below fields "End port" range must >= "Start port"
ID Start Port End Port Port Type Host IP Address
TCP
UDP
- Use the following form to add special port that you want to be opened for your special application."
ID Public Port Private Port Port Type Host IP Address
as you might over look the words highlight in bold
possble happend and see any update on the router (e.g firmware)
