Is Netgear WGR614 compatible with Plus.net ?
Thank you
This is a wireless router and is compatible, but
requires an ethernet modem to work with it,
such as Netgear DM602.
If you already have this unit then you need to
purchase a modem (ethernet not USB).
If not also look at Netgear's DG834G 'all in one' which has
the functions of the unit you listed plus a built in modem.
Alec
Thank you very much.
I think I'll go for DG834G then.
